Mo Morrison
Hi folks,
I have a 2004 GTX 185hp, the problem that I am having is the ski will use 60 litres of fuel in 45 minutes, unbelievable?
I have checked the injectors and they are all operating correctly and delivering the equal amount of fuel, I have replaced the MAPS sensor because my initial thought was it was sending an wrong reading to the ECM, and there is no fuel leaks, the only thing that I can find wrong is the fuel pump is delivering 63 psi of fuel, which should be no more than 58 psi, this would explain the slightly brown smoke from the ski when running.
I would like to replace the pressure regulator but unfortunately they cant be bought separately, does anybody know where to get a pressure regulator for the ski without buying a complete fuel pump at a cost of 450 pounds or am I missing something
Hope some of you guys can help.
