Hi all.
I bought a used 2004 GTX about a month ago. I took it out on the water and after about 15 mins I got one long beep and a chk engine error. The ski ran great before and after the beep but I did take it out of the water for concern of the error.
I turned it off and did not hit set 5 times. After getting home and reading into it I see that I had to hit set 5 times while it's running to retrieve an error code. Next day I took it out again. Ran strong and great for about 15 mins then beep again. Pressed set 5 times and got error code of p0116.
After researching the code, i found that it's a faulty coolant temp sensor. Some said engine temp sensor. Are these the same thing?
I looked up the part number and found a coolant temp sensor on eBay. When installing it I noticed it looked a little different than the one that was on the ski. The one on the ski had a light blue plastic piece that the plug plugged into. And a round copper type sensor that inserted into the engine. The one I got from eBay had a black plastic connector and more of a pointed copper sensor rod that inserted into the engine.
I thought it was probably just a little different because it was an aftermarket part. But now I'm a little worried I either got the wrong part or put it in the wrong place??
I installed it on the back of the engine right above the oil filter.
Antifreeze leaked out onto the engine.
I tried to get as much as I could up.
When I went to start the seadoo it stalled a couple times and ran rough. Then I hooked it up to the hose so I could give it some throttle. It ran without stalling but I noticed the idle speed jump from 2000 to 3000 rpm.
Could this be related to the coolant sensor? I wouldn't think so.
But maybe I got the wrong sensor. An engine temp sensor vs a coolant temp sensor?
Or are these the same sensor?
