2004 4tec swap.
gneauto
So, i have a 2004 non supercharged gtx 4tec. I bought a used engine harness and pump.
What all will need to be replaced to make this happen ?
Ecm,pump,harness,dash, ect...
Replacing the harness doesn't need any new electronics to function. I replaced an entire harness in my wife's 2004 GTX and no re-programming was necessary.
I bought a crashed ski. Just wanting to swap engines to the supercharged one. Have the aluminum pump also.
It should be a direct swap. The ECU just needs to correlate to the engine you're using. But you wont be able to use the supercharger with the non-supercharged engine. And the plumbing for the intake is different.
