Hi Everyone, first post here. I recently bought a 2003 SeaDoo Sportster that needed some work. When I got it I will get no beeps when the DESS what place on the post. After getting a new battery and replacing some fuses I finally got 2 Beeps. Great!!. I knew that the fuel pump needed to be replace so I did. I've installed a new pump(same pump assembly), new wear ring and Steering cable. When installing the steering cable I had to disconnect some of the cables from frontal fuse box(under the console; MPEM I assume) to make some room.
After I finished installing I plugged everything back I do not get any Beeps when DESS is inserted. I have spent many hours trying to find the reason why. I have cleaned all ground cables(that I know), unplugged and plugged back all cables and cleaned all contact points. Still nothing. I have tested the DESS post (following instructions in another site) and seems okay(I have ordered a replacement just in case). Checked and replace good fuses. I have also tested the neutral switch and rechecked the fuel pump. All know fuse are good.
One thing I did noticed is that on the frontal fuse box or DESS if I take out one fuse I do get 12v on one side of the fuse; there is another fuse box in the engine compartment on which I have zero volts in the fuses. Now, I do not know if this get energized once the computer accepts the DESS key. Not sure. Any help is highly appreciated.
