Hello i need some advice on my xp. Everyday i been having to charge my battery up for it to run. After a couple of hours of the battery being in the jet ski. it will eventually die. Could the problem be a bad battery or something else.
I don't know. Is your battery good? Have you taken it to a battery shop and had it tested? Sometimes the bad battery can kill the alternator and vice versa. Check the battery if it is good by charging it and seeing if it holds a charge and do a draw test.
