I have a 2003 rxdi (947 di) engine that has been running great until today when, i seemed to lose thrust out on the water a couple times.  later on in the day the rpm's were limited even with the throttle was pulled all the way and it seemed like the engine was "sputtering".  After going to an idle it would then throttle up fine then after a few minutes the same thing would happen.  As I was getting close to home and idling in, the ski completely stalled and would not start until i took the key out then put back in.  Then it happened again and when i put the key back in a second time, I got nothing- not even a key beep or panel light up.  So when i got the ski home in the driveway it started up and appeared to run fine.  Any ideas, I have no idea where to even start??
