2003 gtx supercharge
keniso
Hi!! I have a problem with my 2003 gtx 4-tec supercharge.
Starting up and taking off full throttle and playing around for half hour but when i let go of the throttle the warning siren comes on and goes into limp mode, no power.Check engine flashes. turn if off and pull the key then restart it no problem got full power etc. till letting off the throttle to an idle beeper goes off again and limp mode check engine flashes again
anyone has any idea, Dealer says it may be the computer
thanks
Ok lets start . I also have an 03. My first time out i got the buzzer check engine light. I stopped the ski and pulled the plug ,restarted and was fine. I posted my problem and dennis helped me out:)
you need to pull out the code.
1- run the ski ,when light comes on push the "set" button five times
2- you will get a " p" code
3- mine was a 1202 oil tank pressure switch
On the forum there is a list of the codes of what they are. I was told by dennis thar this was a seadoo "faulty switch"
Oil switch was not the problem still at the dealership, i think it might be the oil pump, only 60 hours on it.
