Our seadoo shuts down after about a half hour or more of running. the error code is p0351. The problem has persisted since last year and is very frustrating. The dealer replaced the ignition coils last year, but the problem returned and I wasn't able to get it back to them before winter. I checked the fuses, all are ok and clean - no corrosion. Wiring appears to be ok for as much as can be seen outside of the loom/tape. It will start and run for a few seconds and then shut down again. Have done this over and over to get it out of channel/to a safe location to get it towed back in. During the season at the end of last year it would work fine some days, and then act up on others. First time out this weekend ended in same unpredictable result with a shutdown/tow-in.
When restarted, it seems to idle smooth till it shuts down again. Doesn't seem to miss like a coil is bad or not firing. And it will immediately restart after a shutdown.
I also replaced the oil sensors last year to eliminate that issue, though I didn't know about the codes at that time.
