Shop Discount Sea-Doo Parts
2003 GTX Limited Supercharged 1503 Engine replacement
Fightingsioux60
Messages
6
Water Crafts
2003 Seadoo GTX Limited Supercharged
I have a 2003 GTX Limited Supercharged that has a blown engine. After pulling the engine, I have come to the conclusion that it cannot be rebuilt, but needs to be replaced. The question I have is the difference between the Rotax 1503 155hp engine for the supercharged, and non-supercharged application. Can I use the components from my supercharged engine to convert a non-supercharged 1503 (i.e the engine cover, flywheel, etc)? Or are there other internal differences that make this a bad idea?
Thanks!
ski-d00
Messages
2,402
Location
St. Marys, Ohio
Water Crafts
2012 RXPX
2012 GTR 215
2006 3D DI
2008 Challenger 230 430HP
Bad idea mostly because of the pistons are different.
Fightingsioux60
Messages
6
Water Crafts
Thanks, that's the information I was looking for. So there are differences in the engine platform between the 155 supercharged and non SC. If I'm buying an engine, how would I know that as the nameplates are the same? Are there other identifying characteristics?
I'm new to this, so I appreciate the insights.
ski-d00
Messages
2,402
Location
St. Marys, Ohio
Water Crafts
2012 RXPX
2012 GTR 215
2006 3D DI
They added a couple bosses over the years but all blocks are interchangeable with a slight modification from 05 and older to newer blocks.
Fightingsioux60
Messages
6
Water Crafts
Any recommendations on where to find a good used motor that would fit my application?
etemplet
Premium Member
Premium Member
Messages
2,756
Location
Louisiana
Water Crafts
1996 SPI, 1996 GTX, 1997 GTX
What about your electronics when trying to delete the Supercharger? Is the computer the same?
Fightingsioux60
Messages
6
Water Crafts
I'm not trying to delete the supercharger, I want to make sure I get the right engine as a replacement. But you bring up a good point about making sure the ECU is correct for the engine I put in. I'm assuming you would need to change the ECU if the supercharger were removed.
etemplet
Premium Member
Premium Member
Messages
2,756
Location
Louisiana
Water Crafts
I don't understand the negatives concerning the Supercharged engines. If everything is designed properly they should be very reliable. Other than proper maintenance, which people are very lax in doing... they should last. My only question is.... "do they last". :D You are asking more from the engine and components but that is a design issue. Oh well for me... I've read enough and I prefer Normally Aspirated engines as 55 is my max water speed desired. Less Drama all the way around. :D
ski-d00
Messages
2,402
Location
St. Marys, Ohio
Water Crafts
2012 RXPX
2012 GTR 215
2006 3D DI
Basically, all the 4tec blocks and most of the components are the same between sc and na with a few exceptions like pistons, camshaft, ecu, and the block vent system for the new mechanical TOPS in 06. There were some nice updates like valves, sc washers, but you can pretty much interchange all years of 4tec blocks with slight modifications.
The na motors last much longer than the sc ones. They just aren't pushed as hard. Not a bad design, just the way it is.
Users who viewed this discussion (Total:14)
SPONSORED LINKS
Usergroup
