Hello after some thoughts here if anyone can help
Ski is losing fuel pressure around the 5800rpm mark, pressure good up until then sits at around 107 then drops down to the 80 psi tested on the water
Have dead headed fuel pump and goes above 120psi and sits there (after market pump) I get about 25 psi when seas key put on
Have tested compressor and sits at the 80 psi mark and then opens the air regulator, used a pump at the rave valve port, pressure drops off slowly about 3 mins
Have checked to make sure no leaks from rave valve solinoid to rave valves and holds pressure, have tested rave solinoid activation and and can here the clicking have not pressure tested yet for functionality
Does anyone have any ideas on what to check next?
Your help greatly appreciated
