Have owned it one week. Problems but they were to be expected. It’s been sitting unused since 2009.
Put it in the lake and sputtered but finally broke free and ran great.
First problem. Almost sank from hull filling with water. Fixed broken nut on reverse linkage and found LH resonator spraying water through 4” crack.
New to the whole scupper valve thing and thought the missing plug that was exposing that white bell was normal. I assume that’s not the case and needs a plug just like the left side, correct?
After taking on so much water and fixing leaks problem no 2. A rattling noise at idle from the back. I don’t think it’s the motor or supercharger as I used the broom handle to ear trick and can’t hear the noise in either of those areas. They sound good. I assume shaft to pump or a bearing? As well it will now only start but then die. I now hear the standard 2 beeps but then 4 short instead of 3. ???? Google is no help on this. Manual has nothing on 4 beeps.
Last question. Is there an exhaust blockage? Is that why the resonator cracked? I blew air and water through but seemed to exit correctly.
Where do I get a new resonator? Nothing available inline.
And. No codes show. Only “end”
Lots of questions but any help is appreciated.
