H_smith119
so my friend was on my xp 2 days ago and he said it started taking on water bogged down and flipped (with 2 people on it so I suspect they were moving slow and simply flipped it). he tried to re start it and it locked. he got towed back and I immediately dragged it on the floating dock and pulled the plugs and turned it over. water came out but shortly after it quit turning over and the solenoid just clicked. I jumped the leads and it turned over fine. we pulled it out and checked to see if it was even getting spark because it wouldn't fire. we pulled the stator and checked the ignition pickup and it was fine. couldn't get it started that night. the next morning I realized that I had to click the start button so the ski was in the "on" position. got spark and had fire. re connected the oil pump and put everything back together. got it running and let it run on the trailer off and on to get the water out. from the time it "sank" to running was about 16 hours and it was fresh water. now it fires right up and runs well. I checked compression and both sides have within 4 psi on each. I am planning on getting a new starter relay and double checking all the bolts that I removed. is there anything else I should be checking?
