Hello as a new owner of a 2002 X20 I've been frequenting this forum reading several posts trying to work out all the kinks of the boat before spring hits and I can get it on the water. I purchased it during a MN winter and was not able to run on the lake - this was a gamble I know, but the price was right due to the seller moving out of state. I looked it over before I bought it and its quite clean. I did a compression test on it and everything was at least 120psi (without holding WOT), previous owner bought it from a dealer the summer before so I assumed it was at least inspected a year ago and decided to pull the trigger. I brought it home, so far I've changed the spark plugs, replaced inline fuel filter, replace fuel water separator, changed both lower unit oils and the seal on the stator, replaced the ladder because the clasp catch was broken off, put in a new stereo, replaced a broken trailer fender and light, new trailer wheel bearings, etc.
Anyway I'd like to think I'm basically ready to have a good reliable boat this summer but still have a few minor things I'd like to address.
1.) The fuel gauge doesn't work (empty all of the time). I have taken the baffle out and confirmed the float looks good. Jumping the gauge wires will spike the gauge to full so I assume it is my "F1 Fuse" in the baffle. I've seen lots of ways to open these up at solder them or purchase new for $235. My question is - is there any safety risks associated with soldering the terminals and removing the fuse on a fuel baffle? I'm all for saving money but $235 vs the safety of my family...
Has anyone done this and had issues? Is there a way to put an inline fuse in to keep the protection of the original fuse intact?
2.) Is there a way to tell if my engine has ever had the plastic oil pump gear updated? visually with a scope? Serial number of the engine tell what one might be in it from factory?
Thanks in advance for your time and responses! I've already used this forum a lot as a new owner and plan to be a contributing member as time allows.
