2002 Utopia 205 taking on water
I have a 2002 utopia 205 that started taking on water. I have a video of the location while running but this forum will only allow photos. Seems to be coming in around the bolt pattern where the jet exits the hull to the drive. Can these be tightened or is it possibly something worse? I can send a clear video if anyone has a suggestion how.
I had something similar on my 97 sportster. I had to remove the pump and apply some rtv. Easy fix
mine is doing the same thing I think.... replacing the gasket between the pump and the power head.
Try searching -Part 859452
Seems to be loose bolts have they been torqued to spec. See attached this should help.
  • Sea Doo lservicev manual1.1_190.pdf
