TrashPanda
My 2002 sportster single engine is having issues. It will run fine for a bit ( 20 min or so). Then it will stall out. When restarted it will rev up (3500 to 5000 Rpm) but not come up on plane. It just makes noise and feels like cavitation. I can limp it home at half throttle and low speed. If throttle is put to half or more cavitation will return. The plugs seem like the rear plug is wet. New plugs will not fix it. I have not checked the rave valves yet. I do have a mechanic going out to look at it next weekend. Any advice on what to check would be appreciated. Oh on a side thought the water outlet tube thing ( spray nozzle) above the impeller on the back has never had a good spray, just a trickle is that normal?
