remove the return line from the carbs and put a little pressure into the tank. Once fuel starts dribbling out the fitting on the carb put the return line back on and it is primed.
Yes, the fuel pump is on the mag carb and is worked by a pulse line that runs to the crank case.
Plug the return line when you put the pressure in the tank. That will push it through the other way. Then when gas trickles out of the return nipple the system is primed.
