I have a 2002 gtx 4Tec that sounds a check oil or check engine warning on the first start up of the day. The machine then goes into limp home mode. I have checked all fluid levels and everything is fine. The warning usually goes away if I shut the engine off and restart. Sometimes it takes multiple restarts to clear the warning, but it always eventually clears up on its own. Once the machine is done having a fit, it does not do it again for the rest of the day. I have taken it to the dealer, and there are no stored codes in BUDS. I have read in the past about some oil pressure monitors on this engine that are faulty. I have tried to search for these old posts, but can not find them.
Do you think the oil pressure sensors are my problem. If so, does anyone have the part numbers and know where I could order the parts from?
Thanks for your help!
