The above mentioned ski will not crank over after replacing the pump bearings and drive shaft. I have tested the following from guidance from the shop manual.
1. The battery has been charged and reads 12.67 volts.
2. The battery terminals have been cleaned.
3. The starter relay checks out good. There is 12 volts to pin 2 and no volts to pin 1 on the solenoid connector. Shorting pin 1 to ground cranks the starter.
4. Installing lanyard produces 2 short beeps followed by 1 long beep followed by 2 short beeps every few seconds. I think the 1 long is trying to indicate a problem.
5. All fuses in the PMEP and starter relay are good.
6. The TPS checks out good as per the shop manual. 65% throttle will not allow engine to crank.
7. While working on the pump I hit the starter a few times to turn the drive shaft. It worked a few times then stopped cranking. Plugs are out to make turning over easier and to not start the engine. Now it will not crank.
8. Checked out start button.
9. Checked out DESS aux module connectors.
10. Checked out EMS/ECU connectors.
11. Removed battery ground wire and used a different battery connected directly to starter and ground, starter runs.
What could be my problem?? Thanks in advance....Art
