Good day all,
I've been having some problems with the 02 GTI. I ended up pulling the carb off today for a good cleaning. Once I opened that area up I found a small grey hose on the carb, part 44 on any of the card diagrams, part # 270500342 by the book. It's not available anywhere by that part number. And I can't find a fuel line of that small id anywhere, besides some clear cheap looking lawnmower fuel lines. The best description I can find for the part is 90 mm hose. A lot of good that does me.
Now, this doesn't seem to be the evil grey hose that were on the earlier models. This one doesn't seem to have any degradation on the inside. It seems like a poly type hose not rubber or as flexible as rubber. This hose also has a red line down the side, if that means anything.
So, to the question. Does anyone know what diameter hose I should be using to replace this part? Or should I just put this one back on? Is it a special type of hose or can I use a regular fuel line of some type?
thanks
thanks
