bobby2k
Hello all, my first post but I have been lurking here before and after buying my first Seadoo XP (2001)..
Currently I am having issues reaching above 5500rpm it kind of just bangs on 5500 like a hesitation or bog..
On land if I close the fuel selector I can rev it to 7000 but with it set to on or RES it only takes 5500-6000rpm..
I have checked on the water reg. as suggested in some posts - I did not remove it completely but the movement seemed free in it. The setting was on 2 1/3 out from flush, I tested with 3 turns out as suggested, no change
I have just cleaned the RAVE valves completely (small build up) and no change..
Fuel filter and o ring in water separator is changed, but the o-ring seemed to no fit as snuggly in to the groove as old one (can I verify air leak here somehow?)
If I pull choke while riding wide open it dies, feels like it gets too much fuel?
Engine was completely rebuilt for 2020 season with carbs aswell by a shop, under previous owner, fuel lines replaced but with grey lines (still soft and new looking)
Engine has afternarket filters and finger throttle, I changed the throttle cable and setup the TPMS so it reads 5V all the way to ish 80% throttle and then 0.2V
The fuel valve for 951s is the 5/16 version that is 3x the price of the others?
What should I try next? Straight feed from fuel pickup to carb with inline filter?
Best regards, Robin
Best regards, Robin
