I use Mercury High performance gear oil for--- gearbox and stator. It is fortified to keep working even if it gets some water in it. Engine oil- I use Mercury Premium Plus or Mercury Premium oil. Others use Pennzoil Semi-synthetic with good results. Be careful mixing brands. Sometimes they don't do well together.
Injectors- Depends how it runs. If it runs smoothly up to about 6200 rpm, they are probably OK. If you need to have them serviced, you will need to order the gaskets under the throttle body.
Change the gear and stator oil. 2 quarts and a hand pump from WalMart. Detailed instructions at top of this page.
Check steering and shift cables. Move nozzle and gate from stern. Not crunching or grinding sounds allowed. You probably should replace the steering and shift rubber bellows. Yours are 14 years old. Merc has them on a 1 year maintenance schedule.
Upholstery- There was someone here that made upholstery "kits" for SeaDoo boats for the DIYer. He is somewhere here in the states. Don't know anybody in Ca.
When you get it to start, make sure you have water coming out of the pee hole. If none, you may have a bug that made a home in the hose.
