rsatina2002
My engine won't start I did check the compression, the ignition and fuel pump no firing from the ECM and bypass the ground and fuel pump fires but still engine won't start my mechanic told me maybe ECM is bad but maybe there's some sensors that triggers it... anybody knows how to run this engine and what sensors I need to test for ECM failure... This engine was not used for 6 hours per previous owner but He states been running before but it's not used anymore because he was transfer out of state. You help is appreciated. Thank you.
