greatscott73
2001 gtx di. If i pull plugs and put a bit of gas in the cylinders, it will start and run until it burns it off, then stall. Put pressure gauge at filter outlet coming out of pump and get 80 psi. Also broke line loose at fuel rail and get good stream there as well. Its almost like the injectors have just shut off. No codes on the candoo by the way. Any help will be appreciated.
