Currently rebuilding a single carb on a 2001 GTI 717. Followed the carb rebuild sticky. Replaced needle seat valve with a 2.0 that the chart called for and reused the spring that was already in the carb. It’s dull silver spring. The chart calls for a pop off pressure of 36-40 and it’s currently popping at 25 psi. Based off of a Mikuni spring chart I found I would have to use a 1.5 seat with the black spring to achieve a 38 pop off psi. Can anyone confirm this before I order different parts and change out the original spring please. Thank you
P.S Not sure if it matters but the motor was rebuilt by previous owner. Otherwise I’m pretty sure it’s all stock. The reason for rebuilding the carb was a hesitation around 1/4 throttle that would sometimes kill the ski.
