Hello there,
I have read a good 20 to 30 posts now and I think I have some understanding of what could be wrong, still its my first 2 stroke engine and I am a bit lost at the moment.
Recently bought a 2001 gs that needed a bit of love. I rode it a bit last year and it started spraying a bit of water into the hull from the tune pipe gasket to the exhaust manifold. not a ton of water, I could just vacuum it up off the bottom after 30 mins. Like an inch after that long.
I repaired the leak by tapping new holes as the bolts were all threaded. It had a ton of jbweld around the joint, so I lightly buffed the junk off with a sanding disc. the manifold and tune pipe all got new gaskets.
Since I sorted that out, I got it started and it was running well enough in the driveway to take it to the water. Got it to the dock and discovered it has a small leak in the hull, so I popped it onto ahore and filled the holes. It had about 2 inches of water in it when I noticed.
Back out it died on me at full throttle. Just cut right out. Got it home and since then I replaced the starter relay, battery cables, new plugs, new fuel filter, new fuses, cleaned all the ignition coil contacts, cleaned out the fuel selector switch.
After this it didn't want to start until I put a bit of gas mix into the carb and held the throttle open while I cranked it. I ran the engine wot for a bit. Then put the air box silencer back on and took it out. It ran pretty nice for a full 25 mins. it sat for a full day then I took it out and about 100 yards out it died on me, same thing.
The battery seems to be fine. It reads around 12.7 v even after a few failed start attempts. Coil reads good resistance, starter turns really nice. The ignition system seems to be working, I have a spark plug checker but it's tough to see the red flash in the day light. It has been running so it must be producing spark.
The plug I took out today was fairly carbon fouled. This means that the engine is running lean?
I am going to start taking the air box off to clean the flame arrestor,and also start removing the carb for cleaning, as the ski still has quite a few gray fuel and oil lines.
Am I correct in assuming that the problem is likely in the carb? Is it possible that the rectifier isn't grounding the system properly and sometimes I'm not getting spark?
Thanks in advance, this forum is full of all kinds of great info.
K
K
