RebuiltSeadooBaffles
Ok, when I bought my XP in Jan and lake tested it it ran perfectly, I have since then in the last couple months replaced the wear ring and all the fuel lines, I did make certain that the lines were put back into the correct spots, I also pulled 1 of the carbs apart (the FWD one) to check the screens and they were clean, I could not get the aft carb apart to check cause the screws were on too tight, I get it on the lake today, fires right up, idles good, I let it warm up and then nail it and it screamed to 60 mph for about 5 seconds then wham, it cut out down to 30 and no WOT power. If I let it idle for a couple seconds and then punch it from idle it pulls hard, rpms go to 7k for a second then back down to 4700 rpm and it wont go over 30 mph, WTF do you guys think is causing this? Pulling the choke at any throttle position only makes the motor stall, also moving the fuel selector to reserve does not help at all. Has brand new plugs and fresh 100% gas. Pulled the plugs and as you can see below the are different colors in 2 different spots on each plug (the top plug is the FWD cyl and bottom plug is the aft cyl):
