2000 seadoo xpl 951 carb. Is there a way to check engine alignment without taking the jet pump out? I have a new side engine mount to install and want to make sure she is lined up. Also I cleaned my rave valves and replaced the 2 rubber o-rings on the shaft of the valve but they were 2 different sizes? The part manual shows the same part number for each o-ring. Are they the same size?
