D dklswh Active Member Apr 18, 2020 #1 Does anybody know if there is any type of return spring for throttle beside on carbs. my throttle will not return to idle with lever but works fine with cable disconnected from carbs.
C cyaman37 Member Apr 23, 2020 #2 With the cable disconnected from the carbs dose the cable move in both directions by using the throttle.
D dklswh Active Member Apr 23, 2020 #3 It did not, i actually removed cable and took it apart and found oil pump cable frayed inside. going to replace cable.
