Initial setup carbs question
Bartoncraft
So after spending an inordinate amount of time (as mentioned in previous post) figuring out the interplay between oil injector and carb...i still have a question. Where would you set your carbs before you start the engine for the first time?
Also, if any one needs this: my throttle cable pulled out from the splitter that connects the throttle, steering throttle ( on boats its used to smooth turns) and carb s. I 3d printed a replacement and it works perfectly. So if anyone needs me to print them a throttle cable splitter just let me know. I'm printing in PETG so it can be in the heat.
