2000 Seadoo GTX Millennium HELP
SpartansFan2723
So my 2000 Seadoo Gtx that I just purchased quit on the lake the first time I had it out. I tried starting it again and no luck. I took it out and ran it in the garage on a hose to look for any problems. There were 2 bolts on the head cover that were so loose and just spraying out water over the plugs so maybe that? It runs now fine and I tourqued the head bolts down. My other question is the compression reading was at 90 on both cylinders. Would it even run at that low? Is it likely my tester is junk? Please help! Thank you
Recheck with another tester, only way to erase doubts. You say it runs fine now, so take it back out.
