Hey Everyone,
Long back story, but someone else might find this useful!
I finally got everything fixed on my project boat last year and took it for a spin. After about 10 minutes of running around it would stall out when I slowed down. After it did that twice the motor wouldn't turn over and got a tow back to shore. Brought my battery to the parts store for a test and of course they said it was bad ($150 later). I put the new battery in the boat and it started and squealed and died. Grabbed the nut with a socket and turned it over. Found out it was very tight. Removed the plugs and sprayed the cylinder down with some lube. Started spinning pretty good so I started it again and it locked back up pretty quickly. I feared the motor had ran without mixing 2 stroke oil and was setting up.
This spring I again turned the motor over by hand end everything felt pretty smooth, so I lube the cylinders again mixed up some 2 stroke oil in a gas can and ran the fuel line into it. Started the motor and it ran just fine! Smoked a lot. So I "assumed" I found the problem was just my oil wasn't being mixed and I would have to premix myself.
I decided to change the oil in the lower unit and the stator. Pulled the plugs on the lower and about 2 shot glasses worth of oil came out! Read the warnings online about don't lose the gaskets in the plugs, but the gaskets were gone and the last guy never replaced them. I refilled the lower and the stator (which wasn't bad and still had oil in it).
I brought the boat to put it in the water yesterday, started it up just fine and absolutely no thrust! Forward/reverse nothing! Loaded it back up and went home can climbed up the unit. The impeller and shaft spin freely! I believe the impeller is gear driven and a direct drive unit and should only spin with the engine. I am going to again "assume" that I trashed the gears in that assembly based on the low oil and free spinning shaft.
Question #1 Does everyone agree with my prognosis?
Question #2 Do I have to remove the motor to access the gearbox to validate my concerns or can I get in there from the impeller end of things to find out what needs to be replaced?
Question #3 Does anyone have some good instructions on how to do this? I have been searching the internet with little success.
Thanks in advance for the help!
