ssaint45674
As the subject says, the boat won't plane out. Just bout the boat. Motor sounds good starts right up. Checked everything I could think of:
Stator.
Vr/R new.
Voltage 14v give or take some.
Igniter ring new.
Sensors show continuity.
Ign coils check out.
New plugs.
Compression is 125psi.
Oil tank was deleted and I'm not 100% sure it was done right electrically.
Checked wear ring and impeller.
Carbs are wide open, and I added a small amount of brake clean to check fuel intake being too little.
Fully adjusted the ign ring to retard timing.
Switch boxes look newer.
Stator looks decently newer.
Nothing in the grate.
Trim plate adjusted.
No beeps other than the initial turning on.
Fuel pressure/no bubbles check good.
Now only thing I can add into this and I don't know if it matters, the tach doesn't work, nor tank level.
Thanks in advance for any help
Stator.
Vr/R new.
Igniter ring new.
New plugs.
