Well I've read many many hard start posts for 240 efi's and others but didn't really find any for the 200HP Opti.
I purchased the boat this spring with a newer powerhead on it with about 140hrs. It wouldn't start the first time I tried to take it out on the water. It only had a single battery in it and seemed to crank slow so I installed a second battery as it had the holder and cables already there unused. I know these engines won't start if there's too much voltage drop. Took the boat out and it started up great. Then the next time it started great cold and then wouldn't start after docking it at the launch and backing the trailer in the water. Pretty frustrating.. The next trip it started right up cold and I docked it after launching and shut it off and then it wouldn't restart without giving it some throttle. It ran great after that until I docked it again at the launch. I thought maybe it was just some old fuel and starving for fresh air after a long run (I believe the 240efi's may have this issue) Now after a few more runs it's now hard to start cold or hot. You need to throttle it to get it to run and it normally takes a couple tries before you can let off where it will idle. So it's overfuelling and isn't starving for fresh air in the engine compartment as it's opened to turn on the batteries before launching and I even ran the fan.
Once it's running it seems fine. The top speed is only reaching 40mph but I've never been out where there hasn't been rough chop yet.
I had Merc G3 software hooked up previously and the only faults where for what I believe were smartcraft configurations which there's no smartcraft installed. I'm going to hook the Merc G3 tool back up tomorrow but I doubt I will see much.
Any solid ideas on where to start would be appreciated?
