2 carbs on my xp
lilpain
how do i do a pop of test on it.do i have to pull the carbs out do i need to do one at a time .my engine compartment smells like gas can my carb be leaking
could be. If you went threu the carbs, and didnt replace the springs at the n/s assy, no need for tester.
Yes I put the springs that came on the kit .I just order the oem the 80 gram but before I take it apart so that means I need to do a pop off test. Why is it that my engine compartment smells like gas.my question is do I need to remove the carbs to do this tes do I have to do one by one.
probably, the needles stuck, flood'n the bottom end, or a fuel line isn't on tite and/or the "Y" connector for return line, is cracked. Had one of those happen.
No idont I just order them I will put them back on has soon has I get them.wen doing a pop of test on my carbs do I do them stuck together or one by one
need to pull the carbs, and individually do the test, bud. The 80gram spring, you'll receive is, in all hood, a starting point spring. So, with not havingthe oem spring, its a must for the tester. Make sure when doing the test, keep the needle wet..(wd-40)
Ok my final question wen doing this test what is it that I'm looking for and how do I adjusting. To get thing right
