1st try of my boat
Mazda2010
Hi, I've Finnaly try my speedster 1998 after a big gamble ( bought it without test drive) and finnaly turn well boat run very well take of water really fast and engine run great they dont over heat they start very welll in water. The only thing i on my trottle lever on board side dont stay push if you release it, it goes down by himself i always need to keep my hand on it is there any setting i can adjust it . Beside this im very satisfied of my purchase even if it was a big gamble and i thank very much all member who gave me tips of what to check off water before buying it
Thanks a lot
This winter will be a long one
My first season of seadoo boat but probably not the last one im pretty sure
Mine did the same thing. Where the throttles are, there is a white plate. Remove the screws and lift it up. There are screws on the sides of the levers that you can tighten to put more pressure on it.
More...
Be careful about a couple things -
- When you remove the 4 screws which hold the throttle assembly into the deck
there is a metal backing plate under both sides which will drop down into the hull and be gone forever, so you have to be prepared to reach under and tape it, remove it, or otherwise secure both pates, which is hard to do. You couls take out 1 screw and use a piece of wire to hold the plate thru the screw hole.
- Not sure if your boat has dual throttles (2 engines) - if so the tensioner screw for the inside throttle is on the port side of the assembly, I would check the fiche web site to see it, and by all means get a shop manual which states the procedure. There are other screws so be careful which ones you tighten.
- Put a thick towel on the deck the throttle assembly will ding it up when it comes out.
