Hanan peters
My Sea-Doo all of a sudden has a few problems. I found the 20 volt fuse blown and replaced it when I kept getting 12 volt low and had to keep recharging the battery. I also replaced the voltage rectifier. I was also having trouble starting this Sea-Doo this year and the problems were intermittent. Now it won't start at all it just clicks. I'm thinking the starter solenoid needs replacement? Also every time I pressed the start button the clock would reset but the jet ski would start. This was prior to replacing the fuse and the rectifier. I was reading that you could install a four-tec rectifier in this model to get more charge to the battery?
