FYI I am a newby with jetskis but Im pretty handy with cars and motorcycles.
I just purchased a used 1999 Seadoo GTX LTD from a guy, I got a good deal on it, it needs a little love, but after putting a new battery in when I was buying it from the guy he showed me that it fired up it started and then died. The key was really finnicky and he said it might need to be replaced. I was able to negotiate based on the fact that it definitely needed to be tinkered with a bit, and the guy was positive that I would get it running with minimal effort, as last season his daughter used it a bunch.
Anyways a few weeks went by I put the battery on a tender, but when I put the key on and pressed start nothing happened, no gauges no beeps. I checked the fuses in the front they're all good, I tested the continuity on the key and everything checks out, I have continuity on the sides, and I get 6 ohms when I test the center with a side. I know the dess post could be bad potentially. I unplugged the dess post and tried to test it based on a youtube video I watched but Im not 100% sure what readings are out of tolerance for the DESS post.
Yesterday I tried again to regain some power, battery was tested for voltage and is still good, I opened the rear E box, and made sure the connections were tight in there (based on a post I saw on here), it seemed like one of the red wires was a little loose, so I tightened it down, and then put the key on and pressed the start/stop button my gauges actually came to life, audibly I got a single beep and a message for Low fuel warning on the dash, however there seems to be fuel in the tank. When the guy i bought it from went to start it up that day there was no low fuel warning/and we got a double chime and it actually cranked. Later in the day I went back to see if I still could press the button and get that single beep/low fuel warning it went back to being completely dark no gauges no beeps nothing (battery still had adequate voltage).
Before I go out there again to try to tinker with it, I wanted to see if I could get some guidance on here on where to begin.
Im wondering if its the fuel sender? or a bad dess post? or a bad starter solenoid? or even a bad MPEM (which is my biggest fear because its the most expensive of the bunch). Some help/guidance would be appreciated, If im not going to be able to get this bad boy running, I want to try to sell it and get something else before season starts.
Let me know where to start, Im new to jet skis but Im willing to put in the time on it, and willing to learn. Just need some guidance for this ski.
Thank you so much.
Update: Just went out there again and the battery is already down to 6.5 volts, any idea why the battery would discharge that quickly overnight? Temp outside mid 40s, its an AGM battery it was brand new when I bought the ski he went out and swapped the battery at the store. Could it be a bad battery?
Thank you so much.
