GGuillot
Took the ski to the canal today for water testing. It did well. It sure is boring doing the break-in correctly. I know I am too anal about it but it needs to be done right. I gotta say... fuel injection rocks thus far. Hit the button and go. Wear Ring is bad and I'll PM the back end shortly. Next time out... I'll go 50% throttle. I'm gonna run premix with the oil pump for the first few hours.
Question 1 - where is the tattle tale exit port on the 99 RFI? I thought it was on the front left side of the hull just beneath the rub rail. I don't know where to connect this line on the engine. I have that port hooked to the battery overflow.
Question 2 - I need some pictures of the dash so I can see how it was when new. Mine has been spray painted black.
Question 3 - My info center isn't working. Not lit up at all. I'm thinking it is toast but am not spending tons of money to get it fixed. Advice on this is always welcome. Speedo is dead also.
Is the LCD display faded? If not, may be worth it to take it apart. It tends to get a bad connection from moisture inside. Clean/lubricate the large connection between the main board and LCD display. On the Speed O pickup or paddle wheel is likely not spinning like it should, when on trailer, running, you can hit with the hose to see if it spins. Otherwise double check connections or replace it.
Paint on the dash may rub off with some stripper, should be a wood grain appearance underneath.
What is the "tattle tale exit port" you're asking? Whatever it is, if you have a service manual it should be easy to trace down.
