My problem started with ethanol in the gas. I drained the tank and never ran the gas through but same results as if I did run it. I read the posts here regarding changing all the fuel lines checking all the filters and yes the one inside the carb too. I did this to two 1999 GTX limited. One works fine now and the other runs lean and the RPMs screem I have to choke it to keep it from runing away. So I followed all of the steps to insure no blockage in the fuel system and still is lean and runs away. I tried to download the files posted at: (http://www.seadooforum.com/showthread.php?t=5563) for rebuilding the carbs but the files will not open and an: error message comes up saying the files have errors and will not open. Help anyone have any ideas??? :willy_nilly:
