Gazza in sunny uk
Hi all - need some help with diagnosing a fault.
A bit of history first as sometimes this can be telling!
New carb fitted recently and the ski went like a dream for the first time for a long while as I have always had fuel issues until I replaced the grey fuel pipes.
Fitted an inline fuel filter
Fitted a new starter.
All was well until I stupidly left the bungs out on my last trip, ended up getting towed in as the electrics just shut down.
I did notice the starter motor had worked it's self loose under vibration.
Tried to start in when it was all dried out and it eventually started but refuses to re start since.
The ski gives a double beep when the key is fitted, all the fuses are in tact and the engine turns over freely. I have looked at the earth wire in the bottom of the rear box (Where the HT leads are housed) and it's quite rusty, although I did earth this to the battery using another wire, no change.
My dad reckons the MPEM has blown and also says that he has checked the bridge rectifier and thinks this has strange readings.
I'm up for spending some cash but don't want to start buying expensive parts until I have eliminated all the basic checks.
Has the MPEM died, is there a check that I could get done or do myself or could it be just a dodgy bridge rectifier.
Bit of a read I know, but best to get as many facts out their
