My 1999 GSX RFI has a slow leak right next to the waterbox. It appears to be coming from one of the thru hulls. See video below. Anyone have an idea how to fix this? Thanks!
Sorry! I had a hard time capturing it well while standing in the water with the ski. I had a hard time pinpointing where it was coming from. I think it is from the steering cable.
I had one leaking from that area a couple months ago but I found it the opposite way. I filled the back of the ski with water. My water leak found a path along side the through hull connections and out right next to the jet pump inlet. It was small but one of the reaons I always had a little water in the ski.
It might be easire to spot if you put water in the hull. put the ski on a big angle so you don't get water everywhere. Chock the trailer and crawl around with a flashlight. Good LUck
