MSUchurldr
So if it’s showing that my volatage regulator/rectifier is bad via the 12V Low blinking on the dash... does that mean i have to buy a whole new MPEM for the machine. If it helps the key doesn’t beep when it is put in either
Did you test the charging system?
Chester
The first thing to do is put a volt meter on the battery and see what the voltage is in a static state. Then crank the motor and note what the voltage drops to while cranking. Once it starts, write down the voltage at idle and at 4-5000rpm. Reply with what all of those voltages are and we can help from there.
I’m busy tomorrow but I’ll do that tomorrow and report back[emoji1360]
Cranking voltage is not really relevant here. As long as it stays above 10.5 volts while cranking, it will start.
Chester
Chester
You’re right, it’s not relevant to the plugs fouling, but it is a good indicator of battery health, so I was hoping to get that voltage to help rule out problems with the battery itself. Now that he’s changed it, it’s a moot point though...
Well the cranking voltage is fine. I think your electrical system is okay at this point, so I would move on to checking your compression next. 150psi is what you are looking for, and anything over 135 should be okay as long as both cylinders are close to each other. Less than that and you are looking at a rebuild...
Voltage dropped to about 11.5 when cranking, never dipped below 12.5 when idling or accelerating up to 5000 RPMs. Thankfully i don’t think the MPEM or anything like that is the issue. Still won’t start in water under load... hmm
Guys I got a little confused on this one too... The way I’m understanding this now, is the OP has replaced the battery and now has proper voltage, but the ski will only start out of the water...
OP, you should still give us what the upper limit of the voltages you were seeing is, and let us know if you are still getting the flattery light on the multi function gauge. Then I still think you should compression test it, as that’s unfortunately one of the more common causes of running on the trailer but not in the water...
I am planning on taking it in for a tune up so a more experienced mechanic can check it out... but only this once, after that I’m doing all the repairs/maintenance. Yesterday when i started it on land to record the voltage i didn’t get the “12VLow” message at all. Again, I’ll keep everyone posted
I understand the thinking behind that, but be cautious about taking the ski in. The symptoms you are having are a good opportunity for a dishonest mechanic to take advantage of the situation, so do your due diligence before you greenlight having him do major repairs. If they tell you it needs a rebuild, be sure to ask him what the compression readings were and why he thinks it needs to be done. I would also have the carbs done with genuine Mikuni rebuild kits at the same time if you have to have it rebuilt. Carb/fuel issues are the most common cause of trouble on these skis, so the last thing you want to do is put a new motor in without correcting the issue that caused the current one to fail... Hopefully the motor is healthy and it doesn’t need it, but I want you to be aware of those things if it does go that direction...
Thanks man, I definitely was thinking along those lines but it doesn’t hurt to hear it again and from somebody with some more experience. I should’ve taken some pictures so you all could see that the machine is really in great condition, which is why i’m so frustrated it’s giving me a little trouble lol. But yeah I’m definitely on a budget so unlimited repair costs aren’t even an option
