BLand
Hey guys..I have a 1998 rfi that runs great..except for two minor issues that I'd like to fix if possible. They are tough to troubleshoot..Main one is that if you are just cruising..it misses/stutters around 4200-4300rpm give it a little gas and it flies..let off the gas and it hits that range again and it starts the same..its a perfectly consistent problem. Never notice it unless you go cruising..of course that's the cruising around speed. Last issue is that when it idles ..its like the idle can get to low and Iit shakes hard and sounds like someone is slapping the inside of the ski with a hammer..give it a little gas and it idles perfect.ive searched everywhere and even had motor out and can't find anything loose..can I just turn the idle screw up a little on an rfi?
Thanks
Thanks
