Jaxx
Howdy, my name is Jay.
I have a 1998 Sea-doo GTX limited. I'm getting dirty fuel in the top Block. It stopped last summer, and I couldn't get it started. I connected cooling to it trying to start it a few months back and found water leaking in from the exhaust manifold from the 4-bolt flange I couldn’t figure out why I had more water in the bilge than my other Jet ski and that was why. The previous owner snapped the bottom nut on the 4-bolt flange. I think water contamination might have gotten in the carburetor(s). I took the head cover off and noticed dirty fuel spraying into the piston chambers when I jarred the engine. I checked the fuel and fuel Filter, both are clean. The Cooling water circuit is clean when I disconnected the Outlet connection from the Block. In the early stages of trouble shooting I cleaned the piston Chambers before I knew the source of water entering the exhaust. It tried to fireup. I purchase a new exhaust manifold with the stud and bolt. I replaced it and still have a problem with the contamination entering the cylinder from the bottom, I take it’s injecting it from the Carburetor but I'm not sure. I purchased a top end block gasket kit and two carburetor kits to start the rebuild. I’ve been searching the Shop Repair Manual and I’m stuck between fuel contamination and water in the engine troubleshooting guidelines. Please advise on what components require cleaning, replacement or any other recommendations.
Thank you for your time,
Hoorah! GO NAVY!
LCDR USN(Ret)
Hoorah! GO NAVY!
LCDR USN(Ret)
