I recently bought a 1998 GSXL (not 1997.5) and I have been fixing it up to get it ready for the season. The ski had the intake grate ripped off (no idea how) and the front bolts broke off and are still in the hull. I was just going to use a drill bit and extractor to pull them out but then I found out this ski does not have the bolts screwed into the hull. This model has the bolts pass through the hull to nuts on the inside of the hull. I am curious if anyone knows if there is some kind of bracket that keeps the nuts inside from spinning, or if the sealant might have the strength to keep the nuts in place, so that I can just extract them the way I was planning to.
Otherwise, I have to unseal the nuts extract the bolts, replace the hardware and reseal everything up. I am more concerned about resealing everything than the rest of the process. Any help would be greatly appreciated.
Thank you
Thank you
