Mick2279
Hi guys, I have just brought a 1998 gsx ski, it has a rebuilt motor and carbs with less then two hours on both and has been sitting for about 6 months before I got it. Went out for a run and sounds like it has a engine miss at idle and it will only go with full throttle, as soon as I back off just a little bit it bogs down and some times stalls any other throttle position results in it stalling. Have replaced spark plugs but no change, have just drained the fuel tank but yet to refill and check again. Also noticed the low voltage alarm come on a couple of times but not sure if it is related. Hoping it’s just fuel but maybe someone has had a similar problem and can steer me in the right direction with getting it sorted. Thanks
