Hi everyone, new to the forum and to seadoo. I am looking at buying a 1998 seadoo gtx limited. It has a new motor, put in 2006. It has low hours on the new engine. The engine was replace because it threw a rod. I have been doing some research on the 1998 951cc motors and i have been running across mentions that the 951 at full throttle the oil injector (pump) can't keep up and keep everything lubricated causing engines to blow. They mention the fix is to adjust the pump for more oil at top end. Can anyone fill me in or correct the statment of the lose of oil at full throttle? thank you all
