filthyoar
Howdy all. Couple years back I got some great advice from ya all and had my boat running and zipping around the lake. Well during my fixing process a couple years ago I accidentally cross threading a bolt on the cylinder head cover and at the end of the year the corroded bolt broke and water came through the cover. Over the winter we took the cylinder head cover off and then carefully removed the cylinder sleeves and took it to a machine shop to have the broken bolt drilled out.
Last week we got all the new bolts and a gasket set and put it all together again. We did a compression test and got about 125 on all cylinder of both engines. The problem is that when the spark plugs are out of the engine we took apart it rolls over exactly like the other engine does. When we put the spark plugs in it almost seem like it doesnt have enough power to turn over. Anyone have any thought to something we may be over looking?
