dgbehrends
Thanks in advance for any advice.
1997 Sea-Doo Speedster. Twin Rotax engines. Planes fine once I get it up on plane.
Problem: Port engine will die if I try to accelerate rapidly with skier behind me. The problem isn't as much of an issue with no load behind me. In order to get the skier up I have to slowly creep the RPMs up to 3500 or so and then when I believe the engine is engaged can slam it and off we go. If I slam it from idle it will die. No issues with the starboard engine. New plugs greatly help, which is why I change them at the beginning of each season.
Another issue is that in order to keep the same RPMs on both engines the port throttle needs to be about an inch in front of the starboard. This came about after my dealer rebuilt the port engine in 2002 and after a few tries could not get the throttles aligned. They no longer sell Seadoo jet boats so won't work on it anymore. The throttle separation has never been much of an issue over the last ten years, but the port engine dieing is gradually getting worse and worse and it's time to get it fixed.
The boat runs great except for the problem I mentioned above. Both engines idle fine and she runs around 55 on the dream-o-meter WOT. (50 on the GPS).
My guess is that the mixture screw is set wrong or the throttle cables need to be adjusted.
What are your thoughts?
