ravens9273
I bought a 1997 Sea Doo Speedster back in February. The boat looked rough. It was a one owner boat and original owner passed. At the time the boat was at a Mechanics shop and had work done to it. This was the only Mechanic to work on the boat its entire life, so they know the boat well. Original Owners wife gave title of boat to shop to cover repairs. Boat was then sold to me.
Now I am good at cosmetic things. I do body work, paint cars etc... I knew I could redo the look of the boat and I did redo the whole boat over. I also gave the boat a more modern look.
Mechanic told me the engines were good. He had just looked over them. This boat has not been run since early 2013. It was at the shop all of 2013 season since owner died. Mechanic did say however the carbs desperately needed to be rebuilt. Told me $800 to do so.
Now I am the type of person who will do for myself before I pay someone that kind of money. I watched video's on youtube and saw it takes all of 10 minutes to rebuild the carbs. I removed the carbs. Took them apart and cleaned them with carb cleaner. I purchased two carb rebuilt kits (boat only has single carb per engine) and rebuilt them myself.
Carbs are back in the boat. I will admit I know nothing about adjusting them. I have read about the low jet, high jet etc...
Here is where it stands. #2 engine starts with no problems. I used starter fluid for first start and since then it will start with first push of start button. However this engine sounds to be running rough. Just does not sound right to me. I will only run it for about 1 to 2 seconds before turning it off because it sounds that bad to me.
#1 engine will not start at all. It cranks and the cranking sounds normal. This is also reason the other engine scares me. However I cannot get #1 engine to fire. I have tried starter fluid. I poured gas into carb etc.. A few times it spit out of the carb and smoke comes out of the carb. When opening the throttle a little it seems like it really wants to fire but just wont. The boat has a new battery and rebuilt carbs. I am lost on what to do. I spent a lot of time redoing this boat. I was all ready to go out on the water and now I worry if I have serious problems with the engines. I am including and image of what I have done to this boat and its new look. While I am good at the cosmetics I am clueless as to the mechanical issues. Could these issues be related to the carbs and not being set right or is there a more serious problem? Any help would be appreciated.
